Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Screen flickering but stops when pressure applied!
Hi there,
iPad 2 mini was dropped (whilst in a child’s rubber protective bumper case) and although no visible damage on switching on the screen has lines flickering up it rapidly almost like tv intereference. This stops when pressure is applied just above and to the right of the home button, but reoocirs when pressure is released.
Is this a digitiser issue?
Any help appreciated.
Thanks
Kendo44
The digitizer usually only affects the touch function, the LCD is what shows picture so it kinda sounds like thats what your having an issue with if the picture is distorted or irregular. Also where you are putting pressure happens to be about where the LCD plugs into the logic board. There is usually a metal shield over that connection to prevent it from coming loose so its tough to say what happened for sure until you open it and look under that shield. If everything is connected properly you may need to replace the LCD.
I thought that the area where pressure was being applied might be near a socket so thanks, I will open it and see if something is loose and then if required replace the screen.
Thanks again
Is it repaired cause same happend to my air 4 when I apply pressure to a certain area my ipad screen turn black until I stop
Tried getting a new screen?
Not yet, I wasn’t sure if it could be that a connection had come loose, or if a new screen or new digitiser was required.
K Raeburn crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 6,026
