After 25 years from the introduction of the first-generation Range Rover, the second-generation Range Rover—model-designation P38A—was introduced for the 1995 model year, with an updated version of the Rover V8 engine.
Rear wobbly wheel, and rim and tyre A1
2001 Range Rover P38
Fast or slow speed, rear off side wheel wobbles ! Tyre place checked wheel and tyre, balanced it again to no avail. Refitted and still wobbles !
@robinvanboxel check the wheel bearing as well as the hub. Check to make sure that your half shaft assembly is not worn out or bend or has a worn bearing. You also want to check all the bushings of your Panhard rod and radius arms.
This document may help you to get started on thisRange-Rover-P38-Rear-Suspension.pdf
Rob crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 333
