Not working. No display. Better also changed. what should I do?
My Casio fx991 es plus calc not working what should I do? No display battery also changed. Advise me please.
same problem occured my casio fx-991es plus. i changed battery same problem occured not turn on my calculator but working while solar. so i opened my calculator i check the wire connection solar wires are connected properly and battery black wire it mean negative line cut down. i fixed that issue now my calculator working finely. thanking you.
Can you please tell me How did you you fix the issue
Same problem can u say me clear procedure
can you please tell me in what place where the black wire should be connected? thanks in advance
I had the same issue, replaced battery but still didn't work but it works on the solar panels if flashed with a light source. I opened my unit and what happened to my calcu was the black wire were slightly corroded and a with a touch it suddenly snapped at the soldered point. I soldered in back in place and it came back to life.
You re lie I am calcalater man I rip all tha calcs thats what us pros call the calcualtors dont worry I can help at all points just come to address here namaste fremnd Dundrum Rd, Friarland, Dublin 14, D14 W0V6
@shah313 double check to see if there is a reset hole on the back of your calculator. Use a small object to depress the rest button in there. Let us know what you find.
Thanks for your answer but my calculator still at same position.
I pressed the button but still, nothing happened.
Thanks for ur answer my calculator start working
On the back there will be a “P“ button in the middle. Press it and see if there is a difference.
I saw that the calculator was solar, so then I took my device and turned up the brightness and faced it to the front of the calculator. It started turning on
I most likely shouldn’t have been doing my assignment in the dark in the first place ^3^
As it’s screen is not showing anything; Consult with any technical expert as there may be some internal faults which can’t be solved verbally.
Same thing also happened with my calc. So i was searching for the reset button but couldn’t find any at the back. So what i did was i tapped the calc around the solar plate area with my fingers three four times and then pressed the power button. And it turned on.
I dont know how , but your method worked :lol
I had this problem too I opened my calculator still couldn't figure out what was the problem so what I did was my cal works on solar power as well so I turned my cell phone flashlight on and I held my calc display in front of the light and it worked it's not supposed to work when I light is
Lose the calculator
Locate the power button area
Find a screwdriver and use it to scrap/scratch the power button area on the motherboard gently.
This works for me💥
Reach on Whatsapp at +2347068995770 for more explanation.
Taotech Solutions.
crwdns2936753:07crwdne2936753:0 72
crwdns2936753:030crwdne2936753:0 293
crwdns2942667:0crwdne2942667:0 45,132
crwdns2944067:014crwdne2944067:0
My Calculator display is gone. How can I repair it
crwdns2934271:0crwdnd2934271:0 Angel Twayana crwdne2934271:0
Not working properly only working solar power not working on
crwdns2934271:0crwdnd2934271:0 Shubham DJ crwdne2934271:0
It is not working and displaying.
crwdns2934271:0crwdnd2934271:0 Adesoji crwdne2934271:0
Not working and not displaying
CASIO fx-991ES not working even though replacement of Battery. But its working with solar. pls suggest any things for resolve.
crwdns2934271:0crwdnd2934271:0 uppal crwdne2934271:0
crwdns2934275:09crwdne2934275:0
