AC power adapter for MacBook, MacBook Pro, and MacBook Air. Uses a self-aligning magnetic connector that disconnects safely when tugged. First-generation (2006-2012) MagSafe chargers have a slightly thicker, L-shaped connector. Available in 45 W, 60 W, and 85 W versions.
it's showing not charging
Light is ambor indicating it charging, however it's showing not charging. I bought another battery and charger. So frustrated. I cleaned my connectors also. Please anybody have any advice?
Can you give us your systems specs? As I suspect your real issue is within it not the charger.
As Dan said, if you bought a new charger and cleaned the connectors, it's likely a problem with your system or battery.
One thing worth trying is getting the (if applicable) mag safe charging port replaced. Generally a cheap way to start a diagnosis.
Pva crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 102
