Msg "insert SD card again" or "try another card" msg when inserting m
Msg "insert SD card again" or "try another card" when inserting memory card; for all cards. ???
Had that too. The SD slot got stretched a little when a card got stuck once and I pulled it out with a screwdriver. Solution was to add a little thickness to the SD card. Otherwise the metal contacts on the card don't touch the inside connectors ;-)
What do you mean add thickness?
Add some layers of duct tape, for example, on the side w/o contacts.
If methods of @hellofellow won’t help, go to repair shop ans ask to diagnose SD Card slot, ribbon cable and MoBo. Changing slot might help.
crwdns2942667:0crwdne2942667:0 3,089
