Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
MacBook Air 13" fan won't stop running?
The fans in my laptop are constantly running even when I have no applications open. As soon as I turn the computer on, they are on full blast and don't stop no matter what I do. It's so loud and distracts me from everything I do, can someone please tell me how to stop it from being on 24/7?
crwdns2944067:06crwdne2944067:0
Download this app and paste the full main screen here for us to see: TG Pro
Sounds like it's time to crack it open and clean it out!
My fan is on constantly and the computer is running very slow.. Like snail slow!!
However the macbook doesn't feel hot at all.. Please help. I will try the advice given for the fan, however any advice on how to speed it up?? Thanks so much everyone
Sorry, forgot to mention, mine is a 2014 macbook air
. Thanks
worked for me, too.
Are there any other issues you are having with your mac book before you try the following
Try and reset the System Management Controller (SMC)
If the battery is nonremovable:
  • Choose Apple menu > Shut Down.
  • After your Mac shuts down, press Shift-Control-Option on the left side of the built-in keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
  • Release all keys.
  • Press the power button again to turn on your Mac.
If has removable battery:
  • Shut down your Mac.
  • Remove the battery.
  • Press and hold the power button for 5 seconds.
  • Reinstall the battery.
Thanks champ, that fixed it
Worked for me
how do u remove the battery
Sadly that did not do the trick for me and the issue is ongoing
It worked for me. Thank you so much.
Hi everyone,
I followed the suggestions above and went ahead and installed TGPro. I think that this app has a much smarter way of controlling the fans. At least when the app is actually managing the fans, in my case the fan speed won’t max out whereas when the System is in control, fans are working at full speed. I have a MBA mid-2011. I know this article is old but I would like to share my log files if anybody here can give them a look.
thanks
I am having the same problem. I downloaded ETRECheck.
Following is the report generated EtreCheck Report
I appreciate any guidance you can provide as to how I can remedy this problem.
Sadly the original poster didn't follow up with us so we just don't know what happened.
I original advice still holds! You need to diagnose the issue using this tool TG Pro! It will allow you to see what your sensors and fans are doing much better than what EtreCheck can as its focus is more into software causes.
I also recommend using the onboard diagnostics. Restart your system and press the D key. Did your system pop an error code?
Nicole crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 35,541
