Where can I find the IMEI or MEID number
I have an Amazon Fire HD 7 (4th GEN) tablet and I cannot locate either of these 2 numbers. Specifically, I'm wanting to use my fire to accept square payments but the more research I do the more I'm learning this may not be possible.
You find the cereal number by going into settings under device find device options and click on it your serial number will be at the bottom hope this helps
  1. To view the SIM, IMEI, and Serial Number, from any screen, swipe down from the notification bar.
  2. Tap Wireless.
  3. Tap Mobile Network.
  4. Tap Advanced Network Settings.
  5. IMEI and SIM Serial Number will be displayed.
  6. To view the device Serial Number, from any screen, swipe down from the notification bar.
  7. Tap Settings.
  8. Tap Device Options.
  9. The device Serial Number will be displayed.
Thanks for your response. I actually have to tap on settings on my noifications bar and then I am able to tap on Wireless. When I tap wireless I only have 4 options:
Wi-Fi
Bluetooth
Location-Based Services
Airplane Mode
Is my tablet missing information? Should I do a reset to factory defaults? I don't want to have to do this but will if I thought it would fix this issue.
Is there a "More" area you can tap on? If so, try that to be taken into your Settings then located and tap on "Wireless & Networks"
Simply type code *#06#
Type it where, if the tablet is your only working device?? I also am with Brenda Smith. Mine only have the same options.
On dial pad of iPhone brother.
You can find your serial number by going into settings under device click on device options and scroll down to the bottom your serial number will be there hope this helps
Brenda Smith crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 21,251
