7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Vertical black bar on iPad Mini 1st gen, tried 3 different LCD
Hello,
I am currently replacing a iPad Mini 1st gen digitizer and I noticed the LCD had a large vertical black bar. I tried 2 other LCD to see if the problem was still there and it is. Someone told me there might be filters to replace on the motherboard, is it possible? If so, which one would I need to replace?
I got ZXW so if you got the exact part number to replace I can look it up on there.
Thank you.
Here is a picture for reference: http://imgur.com/eaSAgXc
This problem does not have anything to do with the "filters" (in this case L2200 & L2201) IMO. The backlight works, the LCD is being driven...and you have tried 3 different LCD's. Do they exhibit the exact same problem or just problematic in general?
The LCD image is directly driven by the CPU and goes directly to the logic embedded in the LCD. Other than some common mode chokes (L2222 etc. - there are 5) in between the two, there isn't much there. I would check the connectors on the logic board to be certain they are not cracked or damaged. I would also test the chokes to be certain they are letting the data stream through. If you had access to a known-good LCD or another mini to verify those you have, then you could start eliminating some variables.
Let me know what you find, it might give me some other ideas.
crwdns2944067:09crwdne2944067:0:
Thanks for your input. The 3 LCD's are doing roughly the same thing: black bar, not exactly the same position on the screen but very similar.
I already checked the connector and it is in perfect condition. I will look at the chokes to see if they are OK.
Feel free to add anything if you get an idea.
Thank you.
Let me know what you find.
Here is a picture of the iPad Mini motherboard if it can help.
Picture: https://imgur.com/bQooYeW
The chokes seem to be OK from what I see.
Okay, I took the resistance of each choke.
L2202: 3.3 megaohms
L2212: 2.8 megaohms
L2222: 2.8 megaohms
L2232: 2.8 megaohms
L2233: 2.8 megaohms
I guess the one that differ from the others is probably the faulty one?
How are you measuring the chokes?
Between pins 1&4 or 2&3, it should be low resistance (it's just a winding). Between pins 1&2 or 3&4, it should be a very high resistance (such as what you are reading.
Not sure if the difference between 2.8 MOhms and 3.3 MOhms should make a difference. However, considering that choke (L2202) is responsible for the clock signal, it may be the solution. These are pretty common chokes. you can get them at Digikey or harvest one from an iPhone 6 (L2044 - it has a higher current rating but should work) or check other schematics.
crwdns2934275:04crwdne2934275:0
JPL crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 621
