Model A1625. 2015 revision to Apple's set-top-box featuring an A8 processor and 2 GB of RAM.
Can I replace Ethernet port?
The Ethernet port on my Apple TV 4th generation does not work? I've tested the connections at wall, cables, and successfully connected an older Apple TV (3rd gen) and laptop. Is there a diagnostic to check or way to repair the Ethernet port?
Unfortunately, this device's Ethernet port is micro-soldered to the motherboard. You'll need a professional repair person to replace it.
Alternatively, you could replace the entire motherboard. You can do this using this teardown: Apple TV 4th Generation Teardown
Hope this helps!
Andrew crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,189
