iPhone 4s broken battery connector repair
My iPhone 4s battery connector got detached from the logoic board, after soldering it back iPhone isn't charging and restart every 3-4 minutes like screen goes gray black and apple logo comes.
I have one more battery tested with that but there is no difference.
Battery was 57% and 2 hours later 40% while connected to the charge.
Edit:
Have a look at the detached battery connector. Please suggest can it be repaired or not.
It can be repaired I believe that
Your battery connector is not properly installed one of those pins is not getting good contact that's why the iPhone is acting up good luck I have soldering those tiny pins I had to solder and resolder my battery connector 4 times to get it working again GOOD LUCK
crwdns2944067:015crwdne2944067:0:
Hi Mario thanks buddy for the suggestion but i checked all the connector using a multimeter they were connected properly though.
So there continuity to each pin?
Did you accidently remove any of the tiny resistors by the connector?
I ran into the problem your having and it's stressful and a pain and I noticed that 1 or 2 things this is assuming the charger and cable are working correctly was 1. Replacing battery and 2. Resolder the plug once again
I never felt that there is any resistor near the connector.
I resoldered 3 times and everytime checked i got the same issue.
crwdns2934275:010crwdne2934275:0
There should be ics by the connector ignore the jumpers on the image because I can't remember if this was the 4 or the 4s but you should have components next to the connector
I just stopped looking for the answer I have tried a lot also i got few issues like i got it repaired several times from a shop and i found out there that there are no components near the battery connector i think those jumper got detached.
or might be I have lost all those resisters.
You have provided for the 4S
Sabhay Sardana crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,964
