Samsung smartphone released in January 2016. Model SM-J320
How do I fix a black screen?
I had recently gotten a samsung galaxy j3. I accidentally dropped it into a pool, and dried it, I waited a few days and after a while, it turned on. the screen is illuminated, but stays black. Ive tried everything, even a reset but the screen stays black, The phone vibrates and the flash stays on when charging, but nothing happens screen wise, Do I need to get it replaced?
I recently got a samsung galaxy j3, incidentally dropped into water, i dried it up to a week to ensure its totally dried. I put the battery and power it ON, it turns ON. Every thing functions perfect, but there is no light on the screen (dark), Its charging well. Please what do I do? can someone help..
There is a tricky part here. You dropped it in water, therefore it needs to get cleaned out immediate to prevent corrosion. This can be done with 90% isopropyl alcohol
There is still a chance the phone may work after cleaning, so don't give up!
If you cleaned the phone and issue still appears to be the same, then you will most likely need to replace the screen. Not sure if you have the exact model you posted but here is a breakdown for the a J3
If you're not comfortable in this realm, just take it to a shop and inform them it was dropped in a pool.
Hope this helps
my phone is brokekin
Update (09/02/2018)
its my screen my phone is broke
Mikey crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 3,476
