MDR-ZX100 ZX Series stereo headphones made by Sony.
Both the speakers are not working
Both the speakers are not working and I have checked the whole wire and it is working for another speaker and I have connected the speakers with another wire it not working...hence the problem is with my speakers. Please help
nitheesh k unlikely that both speakers have failed. Check the 3.5mm plug. Check it and replace it as necessary, follow this guide Repairing Skullcandy SCS-SCBP SKULLCRUSHERS 3.5mm plug to do so. Different model headphone but identical procedure. you can also check the wiring to the drivers (speakers) by using this guide How to repair Sony MDR-ZX100 and measure continuity with a multimeter from the connector to the drivers.
crwdns2886500:0Skullcandy SCS-SCBP SKULLCRUSHERScrwdne2886500:0
crwdns2956074:0crwdne2956074:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
45 minutes - 1 hour
crwdns2886500:0Sony MDR-ZX100crwdne2886500:0
15 - 30 minutes
The problem is most likely with your speakers, but it is unusual that both speakers fail together. Are these speakers connected to a computer? Such have a power supply inside one of them and if that fails the speakers do not work. As most of these have an external wall-plug supply, check this (measure voltage at the output plug). If there is no voltage just replace the "wall-plug" supply with one of the same voltage and Ampere rating.
If your problem is with regular speakers that you connect to am amplifier I have no idea what may be wrong with both of them.
nitheesh k crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 346
