Mid 2013 revision to the Xbox 360 line of game consoles, featuring 4 USB ports and built-in Wi-Fi connectivity.
Fan not Running! Ventilation insufficiant
Hey everyone! Ive got a great big ol problem.
I get the "Ventilation is insufficiant" error coming up on an XBOX 360 E.
I have opened the device up, and ran it without the case, where i get the same issue. at this time, the fan is never running. i have tried many things to get the fan to run, which are listed below.
1) I Applied 5.5V directly across the fans /+ aGND/ pins. The fan ran, which told me, that the pins on the board are not supplying sufficiant Voltage to the device.
2) With the knoledge gained from above, I Decided to try a 12V Mod, and i spliced the /+ to GND/ of the fan to the /12V to GND/ of the Disc Tray, which still provided no power to the fan.
I am unable to figure out why the device will not Fan On. does anyone else have some information i can use to fix this issue? the device knows it is overheating, but wont power the fan.
I've got the same issue bu I've rugged a 9v battery it the fan vcc pin1 and and (red and black wires). And it keeps the console humming another day
have you mesured the fan headers with a multimeter?
if anything else, run an independent power supply (or jump the xbox power supply), and make it run full throttle all the time.
I've just jumped it to a 9v battery
Scott crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 4,436
