Released in 2010, the Sony Vaio SVE11B11L: also known as part of the Sony Vaio E Series. Produced by the Sony Company and is associated with other models, such as: SVE11125CXB, SVE11125CXW, SVE11135CXB, and SVE11135CXW.
Not didating the hard drive
i removed the cmos battery from the mother board after fixing it back, when i tried to on it, i discovered that the system is no longer dictating the hard drive, so in this case, what do i do?
tanx so much, but i have done that sir, but the issue here is that, the system is not entering BIOS setup, i have been using my F2 command but it has refused to enter setup, is still showing operating system not found, so what do i do next
Remove the computer battery and the CMOS battery for 30 minutes, then replace both and try again to enter Setup.
Boot to the BIOS, by Tapping the F2 key when you Power On. When the BIOS screen come up, scroll to the "Disk #1" setting and press Enter. It should find your hard drive. Save and Exit, and your drive should now be the default.
Good luck,
Russ
onyebuchiadieze crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 350
