Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Proximity Sensor
Proximity Sensor not working on iPhone 3G 16GB White version.
I have:
removed my case
cleaned screen
cleaned around edge of touch screen
used air to blow out speaker holes
reinstalled apple 3.1.2 firmware
rebooted
What can I replace to get new sensors?
You can get the new replacement from ebay. They are very cheap but it will take about 3-4 weeks to receive it unless you want it from the us. Cost about 10 USD. But make sure when you are replacing it to not destroy or damage the Sensor Flex Cable Metal Holder. Hope this helps you
Thanks I am looking at them now, any idea how hard it is to replace? I have to assume it is behind the screen so I should not have to split the touch screen correct?
You almost have to use a pick tool to do the replacement. I find that is the easiest way to do it without damaging anything.
http://hectordtruong.blogspot.com/
You don't need to split the touch.
There is one vague video on youtube which you might like to refer to.
http://www.youtube.com/watch?v=7KXIOyWXu...
Darrell crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 5,669
