Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
iPhone 5s is having troubles with the telephone network
Hello, since this weekend my iPhone 5s is having troubles with the telephone network.
During a phone conversation, there was a cut.
I tried to call back my correspondent unsuccessfully. I tried to send a text message, and it couldn’t be delivered.
I then restarted my telephone, but I did not yet manage to make a call.
I eventually exchanged with my correspondent with Facebook messenger. Which worked very well.
Afterward I was able to exchange text message with a friend who also has an iPhone, via the exchange of iPhone messenger it also worked.
I thought that the problem was settled and I did not restart my telephone again.
It is only the next day, by trying to send a text message, that I noticed that the problem was not settled yet.
I restarted it again and I received text messages from the day before, and missed calls.
Since then, it went out and flared up again alone ... It had done this once last week.
And I sometimes receive text messages 30 minutes after they are sent to me ...
And it was overheating at some point the last week also.
Has anybody already had this problem and if yes is there a solution?
Thank you
This question was migrated from http://meta.ifixit.com/Answers.
Seems like a bad connection with your 3G board that antenna.
Does your phone show any signal from your service provider?
You might need to replace your phone antenna.
Thank you for your answer.
I'm gonna check the antenna, I don't know much about it but I will ask a friend to help me
This is not a issue with your iphone. This is a issue of network problem or outgoing and incoming msg server of your your gsm or cdma network. Sometimes it called call drop.
Try to use your sim other mobile and check whether problem is still there or not. Dont need to check antena. First check that your sim network is fine with other mobile. Also called to customer care and ask from msg server number and manually change to your mobile.
val_lou crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 87
