Factory Reset, unfortunately Google Play service has stopped
Dears,
I have coolpad note 3 plus mobile.. Getting frequent errors saying "unfortunately launcher has stopped". So i did factory reset and rebooted the mobile.
After the restart, its asking
1. select language
2. select sim
3. wifi --> i provided my wifi details and the connection was successful.
After that i am getting error saying "unfortunately Google Play service has stopped" during software update.. Nothing is moving after this error.
Could please help in this regard.
Regards,
B.R.L.Rao
crwdns2889612:0crwdne2889612:0 14
This can't be isolated case. I see many many inquires on the www but it always get buried before any answers.
by the way, I got here because of the same problem and situation.
Clearing Casche or hard reset doesn't or whatever doesn't apply because it after and during a factory reset, so menus are not available...... Yea, rule out "is it charged" ...... duh
Same issue only I can't even get past the "connect to Wi-Fi or use data" after reset. Will not launch into the main home screen & most of time doesn't pick up the signal for the internet.. it's like someone has wiped or disabled the entire interface & main frame almost. How tf am supposed to fix?!
crwdns2933315:012crwdne2933315:0
My phone Reset phone but not software update google play services keeps stopping and google play services has stopped plz fix me my phone please reply me
This is the most annoying message that most of the android users have faced. You can check https://geekermag.com/unfortunately-goog..., link to how to resolve this issue. This site provides the steps by steps guide.
did you get the answer
Please open Google my mobile phone model lenovo A889
I don't know what's going on,it's really disturbing…please help me
Same problem. Can’t use my phone now. Still stuck on Software Update
Did u get the solution for this problem????
Mine already fixed by service center. Need pay the labor cost.
Thanks,no problem,but be sure make good
I can't use my phone,it always stopped byGGoogle play store
Not well my phone
We understand that the new change must not have been simple to adapt to, but we are still surprised by how well you took it in stride. You put a lot of effort into not only learning the nuances of the change but also helping your other team members get the basic hang of it. We are incredibly proud to have you on our team thanks to your strong work ethic. Amazing work! You can also check   <a href="https://www.techinpost.com/unfortunately...>Unfortunately Google Play Services Has Stopped</a>
It is so STUPID that one cannot use their device because of a STUPID "APP" obviously designed by RETARDS.
NOT everyone is interested in such a STUPID "app" as "google play" especially when it STOPS YOU FROM USING YOUR DEVICE.
Well I will suggest you to checkout the following video it might help you in fixing the issue which you are facing right now:
https://www.youtube.com/watch?v=dLzfduY3...
The stupid "google play stopped working" message doesn't stop long enough to be able to do anything on my device/tablet.
"google play" in my opinion was designed by MORONS.
Disconnect from the Wifi. I disconnected and it stopped asking me to copy file. However, once I was in, Google Play still didn't work, but at least I was out of factory reset.
The "Unfortunately, Google Play services has stopped" error typically occurs when there's an issue with the Google Play services app, which is crucial for apps like the Google Play Store, Google services (authentication, syncing), and other core functionalities. If you're encountering this error during a software update and nothing is moving after the error, it could be due to a number of reasons, such as a corrupted cache, a problem with the update, or issues with Google Play services itself.
Here are some troubleshooting steps you can try to fix the error:
1. Clear Cache and Data of Google Play Services
Sometimes, the cache or data of Google Play Services may become corrupted, leading to errors like this.
  • Go to Settings > Apps > Google Play Services.
  • Tap Storage.
  • Tap Clear Cache and Clear Data.
  • Restart your phone and check if the error persists.
2. Clear Cache and Data of Google Play Store
Similar to Google Play Services, the Google Play Store can also encounter problems due to corrupted data.
  • Go to Settings > Apps > Google Play Store.
  • Tap Storage.
  • Restart your phone and check again.
3. Reboot in Safe Mode
Booting the device into Safe Mode disables third-party apps and can help isolate the issue. If Google Play services work fine in Safe Mode, it indicates that a third-party app may be causing the error.
  • To boot into Safe Mode:
    1. Press and hold the Power button until the power options appear.
    2. Tap and hold Power off until you see the Reboot to Safe Mode option.
    3. Confirm the action, and the phone will reboot in Safe Mode.
    4. Once in Safe Mode, try updating the software again and see if the issue persists.
If the error doesn't appear in Safe Mode, try uninstalling any recently installed apps and check which one may be causing the issue.
4. Update Google Play Services Manually
Your Google Play Services may be outdated or encountering issues after the software update. Here's how to manually update it:
  • Check the version number and make sure it's up to date.
  • If an update is available, it will typically show up as an option. Alternatively, you can manually download the latest version of Google Play Services from a trusted source like APKMirror and install it.
5. Check for Software Update Again
If the device is stuck during a software update, it could be due to a glitch or incomplete installation. Try these steps:
  • Go to Settings > Software Update (or System > Updates).
  • Check for updates again and attempt to install any available updates.
  • If the update fails again, consider using Recovery Mode to manually install the software update.
6. Reset App Preferences
This can reset all app preferences (without losing any data), such as default apps, permissions, and settings for apps like Google Play Services.
  • Go to Settings > Apps > More Options (three dots in the top right).
  • Tap Reset app preferences.
  • Confirm the action and restart your phone.
7. Factory Reset (Last Resort)
If none of the above steps work and the error continues to appear, you might want to perform a Factory Reset. This will erase all your data (so make sure to back up your important data first), but it will restore your phone to its default settings, which can help clear any system-level issues caused by the software update.
  • Go to Settings > System > Reset > Factory data reset.
  • Confirm the action and follow the prompts to reset your phone.
brlrao crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 17,683
