Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Battery died and the phone no longer charges
Hi
Background
I opened my phone for a quick look after I had dropped it. cable 2 came out and during my attempts to clip it back in it sort of half-broke the clip.
Problem
when I connect the phone to the PC or to the wall connector it does not charge. When I hold the on button after 3 secs it comes up with the battery sign but underneath it has a plug sign pointing to an electricity sign, which I assume means I need to charge the battery because it is dead.
Not sure where to go from here.
Any advice.
Nice question. + for detail.
Does anything happen when you plug in the phone? Does the screen light up at all? If it doesn't I think you have a dock connector issue. If it does, you may have a battery or a logic board issue. Unfortunately the logic boards cannot be replaced.
crwdns2886500:0Replace a 1150 mAh battery compatible with iPhone 3G and fix problems with charging and battery life.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPhone 3G Battery
$14.99
crwdns2886500:0Replace the 30-pin docking port assembly in an iPhone 3G and fix problems connecting to USB devices, charging problems, loudspeaker audio, and microphone functions.crwdne2886500:0
iPhone 3G Dock Connector
$9.99
adel crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 2,717
