MacBook Air help to identify which replacement keyboard is needed?
Hi Guys, I have a problem with a late 2010 11" MacBook Air which may be water damaged by the previous owner.
I am getting the exact same behavior as AndrewP described in his thread:
Intermittent shutdown: overheat or keyboard short?
"I have a late 2010 MBA which occasionally pops up a dialog box asking "if I want to shut down" then turns off by itself"
After reading the thread I suspect I need a new keyboard and think I can do the keyboard rivet/screw replacement rather than buying the entire top unit.
But I can't seem to identify exactly which keyboard I need to get. Can someone advise?
I measured the MBA screen and its a bit over 11" diagonally, definitely not a 13". The serial number on Apple's checker returns "MacBook Air (11-inch Late 2010)". The last 4 of the serial number is DDQY.
But the model printed on the bottom of the MBA says A1369, and according to Google this seems to be the model number for a 13" MBA. Is there something weird going on?
Are there a few different model numbers that will interchange keyboards without problems? Which keyboard should I get?
Any help is appreciated. Thanks.
We used to be able to get the full machine info from just the last 4 figures of the serial number. Cant't do it any longer. Go here and input the full serial number. Also remember that the bottom cover may have been replaced, so see if you can find a number on the logic board.
http://www.everymac.com/ultimate-mac-loo...
UPDATE
This keyboard should work for you:
http://www.ebay.com/itm/Apple-11-MacBook...
Here's a video on how to do it:
https://www.youtube.com/watch?v=knI4Bgd7...
crwdns2942205:01crwdne2942205:0:
Thanks. That site returned:
MacBook Air "Core 2 Duo" 1.4 11" (Late '10) 1.4 GHz Core 2 Duo (SU9400)
Intro. October 20, 2010 Disc. July 20, 2011
Order MC505LL/A* Model A1370 (EMC 2393)
Family Late 2010 ID MacBookAir3,1
RAM 2 GB VRAM 256 MB
Storage 64, 128 GB SSD Optical None*
So it seems I should buy a keyboard to fit a model A1370? Will a keyboard for any 11" MBA work?
I would think a bottom cover from a 13" wouldn't even fit on an a 11" chassis, if all A1369s are really 13" as Google seems to say.
I was just able to boot long enough to see About this Mac. The serial number matches the one printed on the bottom case and also matches the serial printed inside the case to the left of the trackpad. Did Apple briefly make some A1369 11" MBAs? Could this unit be a misprint or something?
rcm88 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 152
