Why is my power windows malfunctioning?
why is my power windows malfunctioning?
@ventoman, Ronald, Volkswagen Jetta power window malfunctioning. You did not state your exact issue, so I will post more or less generic answer. Check fuses/relays if equipped, loose plug/possibly switch problem, broken wires(normally in door hinge area, power window motor faulty. Use the links below to help diagnose your power window problem. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.aa1car.com/library/power_wind...
crwdns2942667:0crwdne2942667:0 354
