This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
region lock location on the motherboard
Hello ifixit community,
here is my problem;
I have a working motherboard with the wrong region and another one with a broken DRC-WUP graphic chip with the right region. I just want to solder the chip where the region lock is located to the working motherboard.
can someone tell me, where the region lock is located on the wii u gamepad motherboard?
Thanks for helping,
rgds Thomas
I can’t confirm that.. I bought USA region mother board and took that chip from old board. Still wrong region gamepad. But.. I can’t be 100% sure that broken motherboard was EU region like my test console.
I found it out mysef. You just have to replace the U10 Micron 25Q256A 256 Mb Serial Flash with your original. Then you can use a motherboard with different region
This is not a permanent fix and the gamepad will only work with the Wii U console that the old Gamepad was paired with. This might be fine in the short term, but if anything forces you to re-pair the gamepad you will be out of luck. On that note, if you try and pair the gamepad to another Wii U, it will fail with error code "165-9901"
"The update cannot be completed using a Wii U GamePad designed for a different region."
Hi! You're gamepad is working??
after installing the new motherboard, follow wiiu.hacks.guide to install aroma cfw and this will allow you to bypass the region lock via software
Hannah Thomas crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 2,915
