Repair information and guides for saws, including circular saws, jigsaws, and scroller saws.
Why is it losing power? Where to buy parts?
Craftsman Model 315.172110 jig saw, it's losing power. I ASSUME the brushes need to be replaced. Not having much luck finding replacement brushes online. Anyone know, first, if this is the issue and second, where I can find a brush kit?
Dan Krier describe the "it's losing power" situation a bit better. If the brushes are worn then the jigsaw will not work. Not working means absolutely nothing working.
Dan Krier, I had the same result as you after doing a good search brushes discontinued and no alternative part listed. If need be, in the past I was able to order similar brush to what I required in a old saw(new brush was a little wider) so all I did was sand it down a bit to fit, reused old holder/spring and it worked very well. Below is a sample of brushes that are available for power tools. etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.amazon.ca/s/?ie=UTF8&keyword...
http://ohiocarbon.com/products/power-too...
Dan Krier crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 118
