Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
crwdns2934591:02264crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Small Black Square Rubber from Home Button area
When I took off the home button, a small black about 1/8 inch square rubber piece fell out. While gently peeling off the heated cable.
Can anyone tell me where this is supposed to go when I put the home button back on.
It goes over one of the two screw hole right under the home button.
crwdns2942205:01crwdne2942205:0:
Yup, @scottpine is correct. It is the small piece that covers the screw brackets attached to the bottom of the screen. The picture was fuzzy and I should have seen that so good catch.
Not too sure what rubber piece you are taking about with the home button. There is not rubber peices on the home button of the 7 or 7 Plus. Can you take a picture of the piece and where it came off and I can tell you what is it and where it goes?
Can you also confirm that you have an iPhone 7 that you are working with?
Here is the picture
Did you ever find your answer? Same issue here. Fell out while removing glass (shattered to bits...)
Never did find where it came from. Whatever it is, it made no difference to the phone. Repaired many other i7 and never came across this rubber piece.
The black rubber piece may have come out of another section of the phone. It was probably dislodged earlier and was just waiting to fall out. I just had one fall out of my i7.
Joe in PA crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,422
