Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
Why is it so slow to charge
It take 8 to 12 hours to charge
Could you take a picture of the sicker on the power supply?
Adding images to an existing question
It has no sticker on it sorry
Is it a USB power adapter? If so, does it specify the amperage? Such as 1A, 2.1A?
dustyrob456, Possibly faulty battery/connection, weak charger or perhaps loose/dirty or damaged charge port. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connection(Qtip dampened with 90%+ Isopropyl Alcohol) and reconnect/install battery, still not charging battery probably faulty. Below is a guide that will get you access to battery, connections and enable you to check for other possible loose/bad connections and components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nextbook 8 Battery Replacement
dustyrob456 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,407
