Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose Gold, Gold, Silver, Black, and Jet Black.
Kill Switch if update to 10.1
Has anyone had any issues with the iPhone 7 repair and home button not working? I spoke to someone at Apple. They said they designed a Killswitch if they have a certain update on their phone the 10.1. if theres any repair done to the phone it does a kill and the home button won't work.
In my experience, if you have a non-apple home button then you shouldn't upgrade. I've attempted to do so and ended up with an iTunes error -59 (I believe) that I couldn't get to go away no matter what I tried, including updating without any home button.
However, I have upgraded a hundred phones with everything from battery, to screen, to charge port replacements that worked just fine. Just stay away from replacing the home button at any cost.
What repair did you conduct on the phone? Apple did put a software kill switch on the home button itself if it were replaced, but I havent seen any other repair cause that. However , that being said, I did have a repair end up with no home button function after replacing the screen. I switched to another screen and the issue was resolved. Remember your screen is like the middle man between your home button and the logic board. The button plugs into the screen and the screen plugs onto the logic board. A cheap or faulty screen can contain low quality components that affect the signals your phone and home button are sending. Ive seen this issue once on an iPhone 7 and several times on 6s and 6s Plus models that have the button connector integrated into the backlight assembly. Hope this helps,
Jake
troy parcelles crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 149
