The Samsung Galaxy S5 NEO (SM-G903F) has a 5.1 inch Super AMOLED display with Full HD resolution. It's front and back cameras clock in at 5 megapixels and 16 megapixels respectively.
My charger cannot insert into my phone
while i was out, i noticed my phone was going to die, so i put it to charge for about 10 minutes and took it out. half an hour later, i decided it would be a good time to leave it to charge again, but the charger wouldn't go in. i then went to try multiple chargers, none of which would go in my phone. i asked a friend and he says there's something stuck in there. i don't know if that's the case because my friend says the charger i used still worked, but i still don't know what's wrong.
Either something is stuck or it's damaged. The actual connector inside the port likes to separate into two pieces after a while. Then you jam in the charge cord and damage the connector. Really common. If you take a close look into the port you can usually check and see if there is any noticeable damage.
Hopefully its not broken, as it's a rough repair to replace the chargeport. I would take it to an awesome technician unless you want to break the LCD and be stuck with a $150+ repair!
Try cleaning it search in the youtube whats the best thing to clean it .just be very careful not to damage the part inside and dont ever put your connector in force it might really break the internal .It will really cost much in solving that issue and definitely will open your device .
Rachel Harper crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,335
