Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
iPhone 5S error 4013
My iPhone 5S was water damaged and died for more than 4 months. I have just opened it up and tried to connect to iTunes and suddenly, it worked. iTunes said that my iPhone need to be restored. I tried to restore and error 4013 suddenly appeared. I just wanna make sure that nothing in my phone is broken. Home button, screen, battery, power button are still work.
Update (05/20/2017)
I change another cable and then "error 21"
crwdns2889612:0crwdne2889612:0 10
Error 4013 can be caused by NAND issues. Because your device was water damaged, the logical thing to do first is to have it properly decontaminated. Water tends to seep under IC's and can cause corrosion, shorts etc.
You could try the following yourself:
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
You should also consider getting a new battery if it has swollen. Resist the temptation to !$$&*/pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
crwdns2889612:0crwdne2889612:0 11
I tried to remove the logic board but I can't lift it up so I reassembled it. I changed the phone and the screen turn black with white strips after showing Apple logo. Did I break anything?
@toanvu No. You're only connecting it improperly. It happens. You need to be very precise with the connectors.
Did you remember to remove the sim-tray?
please some one give me solution a bout this problem to fixs i-phone 5s error 4013.
i think that i nand flash error 4013,and then how i get that ic nand flash original that answer mt trouble....thanks for your help
toanvu crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 60,504
