Suddenly WIFI Not Working
Hi,
I am dealing with a strange problem. I have a laptop, it was working fine with 2 different WiFi connections. 1 is Mobile Wifi device the other is DSL Connection with Wifi Router. I got this DSL Wifi router connection like 10 days back.
Suddenly, 1 morning, when I got up and tried to connect the laptop with DSL Wifi router, all I saw was yellow exclamation mark, but after a minute or so it connected, but the Wifi was showing "No internet connection". However, my iphone and other laptop can still see that wifi connection and can browse the internet with no issues.
This laptop (the one have problem) - can easily connect with the other Wifi Connection with no issues. I checked the DSL Wifi Router, it has a limit of max 32 clients so that is still not a problem.
I updated the drivers etc, but nothing works. Unfortunately, I cant restore to a previous date as it is not enabled.
please help me !
Regards
ZH
Have you reset the router?
Yeah I did it a couple of times.
Some one please HELP me !
If you right click on your network icon and select "troubleshoot problems" does windows pick anything up?
I had another router, I connect that router to the Original DSL Router via Ethernet Cable, and then connect my laptop with this new router, and it works. Does it mean that there is something wrong with the Original DSL Router ?
Have you tried to reinstall your Wifi drivers?
(You need administrator privileges here)
In Windows: Windows key+Pause then Device Manager after that find your Wifi card and uninstall the driver and reboot. Windows should reinstall the driver on boot up.
Okay I will try this tonight.
Unfortunately, this did not work.
You might have to disassemble the laptop and replace the WiFi card or if your laptop is still under warranty send it in for repairs.
Okay but what would you say about the same laptop can access and work fine with other Wifi device. But not just with 1 DSL Router.
Hello zeeshanhashmi ,
Checkout these steps Before You Give Up -
1- Update the Wireless Driver Software
2- Go to Wireless Adaptor Properties >Power Management >Allow the computer to turn off device to save Power and Please Uncheck the Box than Apply And Ok
3- You Might wanna Do the Network Reset By Going into Network Settings
4- as i am assuming you are Using The Home network Please Make Sure you Have selected Home network under your firewall
Update your antivirus Program .
Source - https://fixingblog.com/windows-laptop-wo...
Thanks
i think you might wanna change the Security Mode On Your Router for it to work
hello even in my phone i am having the same problem. Its been days network says its connected but is not working at all. It works fine with other networks and works fine with other phones why is it not connecting to my phone . I also need help
help its so boring without wifi and cnt get any work done . cry.
I remember I had a Netbook that worked o.k. with some routers, but not others. It needed a driver update, then all was fine.
zeeshanhashmi crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 10,843
