Guides and repair information for 49cc gas-powered scooters.
No start on electric starter
My scooter starts fine with kick starter but has no spark when I try to use electric starter.
It has new battery and ignition coil and plug.
Turns over fine just won't catch
@lawless sounds like a wiring issue. What make and model is your scooter?
I have a Yamaha tweet 50cc kick start works but not electric starter l have new battery new starter botton n spark plug what else can it be
Check for spark at your spark plug. Replace after testing the CDI. (Capacitor Discharge Ignition) Replace coil wire. Check the starter relay with a voltmeter. Next check the voltage regulator. The last worst-case test is your Stator. Can also be your timing is off. I just performed all these steps except replacing the Stator but that tested alright with the meter. I still think 1 of the New ignition wires is grounding out my kill switch, ran fine until I replaced the New Ignition Module Assembly because I lost my keys. I will post when I resolve Which Wire is the Problem.! P.S. Electric start working fine now after changing some wires around on the ignition( New 1 has 5 wires and only 4 connect. The kickstart will not start it though, barely turns the engine.
Phil crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,102
