Wont idle when warm
Truck has a 22r. it runs fine until warm then it wont idle.
@lvec1 , Lou Vecchia, Possibly a stuck EGR valve or vacuum leak, although there are a lot of things that could cause idle problems, dirty carb., weak fuel pump, clogged filter, bad plugs, failing coil, etc. etc.. Links below may help trouble shoot your issue.
http://www.toyotanation.com/forum/80-89-...
http://4x4wire.com/forums/ubbthreads.php...
Ok Thanks. ill check the links.Going to work on it on Thursday.Ill post what i found. I have replaced the carb and checked for vacuum leaks.
my 2003 toyota truck will run but will not idle and dies
new gas tank and fuel pump and new idle senor. new fuel filter
Lou Vecchia crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,100
