Help me analyse a power adaptor problem
Symptom: for while I've had to twist the power-plug in the iBook's socket for the light to turn orange and it to charge. Now, it is nearly impossible to get that spark and the battery's lying empty, so the thing won't start.
Possible cause: I've had the loose airport-card problem some years ago and took the thing to apart to fix it (scary operation). After putting it together, everything worked, except the power was flaky as above.
Questions:
did I loosen something opening it and can it be fixed by attaching it again?
is the power supply screwed and does it need to be replaced? Can I install it myself?
Thanks for your help. I'll be here to answer follow-up questions.
