A baby monitor made by Infant Optics, Inc. The DXR-8 features a 3.5" screen , temperature sensor, night vision, and an interchangeable lens system.
Can you recalibrate the thermometer?
The thermometer/temp reader used to be very accurate, but now seems to be showing a high temperature compared to what the actual room temperature is. Is there a way to re-set it or recalibrate the thermometer?
@camillelynn I read through the manual. There is no reset option or reset button.
What I can suggest is completely disconnecting the battery and wait a few minutes and reconnect the battery. Maybe whatever miscalibration will reset in this manner.
They have a dedicated help line at info@infantoptics.com which may be able to let you know if this is a hard ware defect or simply a reset fix.
Thank you for your thoughts! I'll give that a try.
Did this work? It doesn't work for me, and the temp has never been right. I just now figure that it's always a few degrees cooler than what it actually says. But that's frustrating.
I have a different issue.the temperature moves up and down from the top to rhe botton.After that, stops and shows a doble H H and the celsius or farenheit symbol . Any suggestion? Thanks
Camille crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 22,035
