I put my iPhone 7 in the water
I put my iphone 7 in the water, and after 15 min it is doesn't work
The iPhone 7 is splash, water, and dust resistant and was tested under controlled laboratory conditions with a rating of IP67 under IEC standard 60529. is water-resistant. Splash, water, and dust resistance are not permanent conditions and resistance might decrease as a result of normal wear. Do not attempt to charge a wet iPhone; refer to the user guide for cleaning and drying instructions. Liquid damage not covered under warranty - per Apple
What does IP67 mean?
Unfortunately, either your phone's trip through water exceeded these conditions or your phone didn't meet it's own specification...either way, Apple doesn't warranty water damage.
The sooner you get your phone to a professional, the more chance you have of recovering it. If you want to try yourself, do the following:
You should also consider getting a new battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
I would immediately take it apart, and clean it with with 90% isopropyl alcohol. The longer it set as, the more damage, and less likely for you to be able to repair.
After taking part the iPhone you should take out the battery first.
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 166
