Lamp replaced still no picture
I replaced lamp with new one. Still no picture. The lamp just flickers and makes crackling sound
crwdns2889612:0crwdne2889612:0
0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 160
@ged52 did you check the ballast as I suggested on here No picture even though lamp replaced
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
Not yet. I need to get a meter.....the one I have has a bad wire. When I check it can I insert the probes into to lamp connection points or should I check it some other place for the voltage. I believe the proper voltage reading should be 280 V. Is that correct. Thank you for your advice.
crwdns2934271:0crwdnd2934271:0 Greg crwdne2934271:0
I put a meter on the connectors for lamps and it blew my meter. I had it set on 700V. Not good
@ged52 the voltage between the power board and the ballast is 220 to 440V but on igniting the ballast can exceed 1000V
I checked the voltage to the ballast assembly coming into the board and it is Ok.
