Repair guides and support for motorcycles manufactured by Yamaha Motor Company.
Bike hesitate to start
When i parked my bike for 3+ minute in sunlight it doesnot start.I have to try 3-4 time to start only then it starts.WHY??
Update (04/29/2017)
Bike :Yahama R15 v2.0
Year:2015
i tried but same only starts after 3-4 times
Thank you
crwdns2944067:08crwdne2944067:0
Is it possible that the gas tank heated up causing excess pressure that pushed more fuel into the carburetor and the engine flooded? Or another fuel system issue could have flooded the engine causing temporary issues. Just a thought.
Did the issue only occur once, or is it a recurring problem? It might also help to know the make/model/year of the bike, and whether the bike has been modified in any way.
@umesh9 just to clarify something. Did you just drive the bike then parked it for 3+ minutes, and it did not start right back up? Does the same happen when you park the bike for longer than just a few minutes? You service your bike regular (new Plugs, oil changes etc.?) This is a relative new bike, any warranty on it that can be used to get it diagnosed?
Hello sir.it's FI version so no carburetor and sir its recurring problem
@umesh9 Did you just drive the bike then parked it for 3+ minutes, and it did not start right back up? Does the same happen when you park the bike for longer than just a few minutes? You service your bike regular (new Plugs, oil changes etc.?) This is a relative new bike, any warranty on it that can be used to get it diagnosed?
Thank you all experts of ifixit and all those riders who have replied i really appreciate
I'm familiar with this . If you use low octane fuel with ethanol it causes the fuel to vaporize in the injectors when left in extreme heat and the bike doesn't start . Stay away from ethanol blends and try to use at least an octane of 90 +. The ethanol can also cause a green sludge to form at the tip of the injector if the bike sits for long periods of time . It can also mess up carbs in carburetor motorcycles .Hope this helps
@umesh9, Umesh Shrestha , Make, model,year,engine may help in answering your question. Perhaps try removing your gas cap and staring the bike, as the vent hole may be clogged/clogging not allowing proper fuel flow. Ensure that the battery is good and fully charged and spark plugs are not fouled(may be just install a new good quality set to rule them out). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Update possible fuel pump/module related, check link's below.
http://www.xbhp.com/talkies/help-me/2309...
https://www.youtube.com/watch?v=z5LjAC3s...
Hello sir.it's FI version so no carburetor and sir its recurring problem. thank you
Umesh Shrestha crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 2,231
