broken connector for the camera and FaceTime
The silver connection for the camera cable has broken off at the board. Is this fixable on a MacBook pro A-1398? If so where can I buy the connector. Its a flimsy connector that takes very little to displace from the board.
Ever since this happened my fans continue to run at high speed. I have attempted on several occasions the recommended resets by apple but this hasn't solved any of the issues.
Did you figure anything out? Happened to mine as well. Thanks
Melted the connector. No sucess
I am assuming that you have a 15" Retina MacBook Pro model between late 2013 and mid 2015 - you wrote A1398 in the question but chose a different model to file the question under.
You can replace the connector, however, this will require soldering equipment and some experience with microsoldering. You can buy the replacement connector here: https://beetstech.com/product/isight-cam...
Kevin crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 489
