Touch ID after emmc flash replacement
Hello there
I have problem with my iPad air 2 wifi model. Afletr update I got error and apple service diagnose my iPad as damaged flash memory, I don't have warranty. I just wonder if I will replace emmc flash on my own will touch ID still works ? I can buy new already programmed emmc but problem is that this flash has other serial number then my iPad and I dont know if this will kill my touch id.
What do you think ? Thanks for any advices
Thanks for reply Minho, I already seen this site but shipping costs to my country are higher then emmc chip itself :/ so if I will solder emmc with other serial touch id will not work ? I know that if I change whole motherboard touch id will not work but I wonder maybe there is some id controller on motherboard which will allow to work finger print scanner even with emmc with other sn ?
If you are referring to replacing the NAND memory chip on the logic board, some suppliers (VIPProgrammer I believe) offer to program it in advance with your device's serial number. This will allow your device to work properly but you obviously lose all of the data you had originally. Hopefully you have a full backup in iTunes or iCloud.
Replacing the NAND requires micro-soldering with good quality tools and plenty of experience.
The Touch ID SN# (on the home button) must match the NAND and CPU.
Thanks, as you advised I will order from vip programmer with my serial, thanks a lot for your help :)
In which website I purchase new sn#
sofles crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 651
