Overheating on left hand corner.
After 10 plus minutes left hand corner of machine gets hot. Eventually almost too hot to hold. Fan appears to be going.
you can read here for solving
https://www.knowerstech.com/hp-pavilion-...
Hi,
Left hand front or rear?
Are the fan vents clogged?
Does the laptop shut down of its' own accord?
Here is a link to the service manual for the laptop.
It will help in the dis-assembly of the laptop so that you can check that the fan is OK and not clogged etc. and also to ascertain where the heat is coming from.
https://h30434.www3.hp.com/t5/Notebook-S...
yes its the chip with small metal heatsink but not connected to fan. how do you think i can get cooling solution hack for this
same here, my fan area is perfectly clean. im blaming the 3rd chip in that area which i dont know what it is. but i havent open case after running it to prove it. hot area is what u rest you left palm. what to do its too hot
Mike crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 6,489
