@jeff1 ,William, You did not state your model, so I will post some generic suggestions. Check the free wheeling lever at the rear of tractor is not engaged(1st link) and park brake off. Check to see the belt is still on and not broke/stretched and for worn pulley's. Check for hydro-static fluid leak or low fluid. Check clutch to see if it is engaging when you switch on, if not check battery condition as it needs good charged battery 12.4 +Volts to engage clutch normally, also could be bad wire/plug/switch for clutch, Control linkage out of adjustment, Internal pump damage. Check the 2nd link as you may be able to get your manual using your model # for more trouble shooting on your issue and suggestions. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=Pc5v9vB3...
https://www.searspartsdirect.com/riding-...
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
7
crwdns2944067:010crwdne2944067:0
have you checked the lever is connected to the trans
crwdns2934271:0crwdnd2934271:0 Cameron crwdne2934271:0
I have a 5 speed mower will not move in any gear : but I hear clanking noise from transmission what is the problem
crwdns2934271:0crwdnd2934271:0 Sammie Daniel crwdne2934271:0
@cam2363 yes lever is moving in to gear butmower will not move belts are tight I raise back tires off ground both are turning but once I put mower in first gear no movement
may be the belt that is under the battery I'm replacing mine
crwdns2934271:0crwdnd2934271:0 heardj71 crwdne2934271:0
I have replaced belt. Mower moves very slow foward sometimes not at all .Will still move in reverse
crwdns2934271:0crwdnd2934271:0 gnfturbo87 crwdne2934271:0
crwdns2934275:05crwdne2934275:0
