The Ford Super Duty (also called the F-Series Super Duty) is a series of trucks produced by Ford Motor Company, an American automaker.
Headlights will not turn off after the key has been removed.
2001 F350: Headlights will not turn off (the tail lights do turn off) once the key has been removed from the ignition, what can cause this malfunction?
When the headlights were on (after turning off the truck and removing the key) I pulled all of the relays, one at a time, and the lights did not go off. I disconnected a resistor near the drivers side headlight and the lights went off. I'm not sure what the resistor is for (perhaps the Daytime Running Lights - DRL). I don't believe it is the resistor because power is being fed to the resistor from somewhere.
Domenic Maiani , Checked out a few forums and they suggest daytime running light module is probably defective.Link below may help with schematic and locations. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.justanswer.com/ford/18so2-hea...
Did you ever fix this problem?
Domenic Maiani crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 7,548
