Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
2001 Club Car 48 volt new batteries shuts off charger
I have a 2001 48 volt Club Car with brand new Trojan batteries. I have charged it twice and both times the charger shuts off like it is fully charged, but the charge does not last very long at all less then 10 minutes. Any answers?
It seems like there might be an issue with the Club Car's new 48-volt batteries causing the charger to shut off prematurely. It's essential to ensure that the batteries and charger are compatible and correctly connected. I'd recommend consulting a professional or the manufacturer to diagnose and resolve the problem for a smooth charging experience. Safety should always be a priority when dealing with batteries and electrical equipment.
Read Our Blog:
https://golfcartsguide.com/blog/how-to-t...
My charger click on and vibrate but the dc amperes stays down,..?
jgottard , Info obtained from the link below. In general, if the charger kicks on, but doesn't charge fully or kicks off soon after, this is likely a charger issue. If the charger makes a loud clicking noise, this is likely a battery charger issue. Very often it's a battery problem. The easiest way to determine whether you have a charger problem is to test your charger on another cart, or test another cart's charger on your cart. ((continue reading)).
48 volt Club Car, you may have a non-functioning OBC (onboard computer). Since the 1995, 48 volt Club Car's come with an OBC that regulates the batteries' charge. When you plug the charger into your Club Car, the OBC will tell the battery charger when to start and stop charging based on the voltage levels in your batteries. As a result, golf cart battery chargers for 48 volt Club Cars need a working OBC to get them to start charging. So, it is possible that your OBC is malfunctioning and it is not the golf cart charger. This is only for 48 volt Club Car golf carts. If you have not manually charged your batteries and checked your connections, please do those first before assuming you have an OBC issue. The link below may have other good info. for you. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.golfcartgarage.com/golf-cart...
jgottard crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 31,750
