The second-generation (Mk 2) Ford Focus was launched in 2004 as a three- and five-door hatchback and an estate variant.
Why is my radio not turning on?
whenever i turn on the car the time will flash on then turn off and my radio wont start up
Did you push the power button on the radio?
yes i did but still off
I have a 2010 Ford Focus SE radio won't come on What's . Show ever
First thing to check is the fuse.
@col_panek This is more of a comment not an answer. Also, the op said the radio flashed, assuming there is power going to it
I never assume anything.
Hi @jasonoverbey4
Check that fuse #28 (& possibly #39) in the passenger compartment fuse panel are OK. The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the fuse panel cover to gain access to the fuses. To remove a fuse use the fuse puller tool provided on the fuse panel cover.
Here’s an image from the owner manual to show you the fuse locations in the fuse panel.
(click on image to enlarge for better viewing)
grace.sept.26 crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 7,485
