The Toshiba Chromebook 2 laptop was released in 2014, and the model number is CB35-B3340. This Toshiba Chromebook is silver with a 13.3" high resolution screen.
The screen keeps flickering, and at times goes entirely black.
The Screen on my Toshiba Chromebook 2 has recently started flickering and going black for a few seconds. When hooked into an external display, the external display works perfectly. Do you believe a replacement screen will fix this problem?
my chromebook is lenovo 500e and my screen flickers sometimes and it scares me i think its the music im playing right now is causing it
Mine is a hp Chromebook and I have tried resetting mine and now instead of better it's worse and it's now starting new every time I turn it on someone please help
crwdns2933315:07crwdne2933315:0
Yes, It should as it sounds like a bad cable. See if you can find a display cable on ebay for cheap and if you cant, try to find a broken one of these chromebooks without a broken display and transplant it as it will probably be cheaper then a new screen.
Toshiba Chromebook 2 Display Replacement
Are you on developer channel? Try changing channel to stable, apply power washing setting, then update and restart
mine is brand new i have tryed like 5 displays and it still does it
I had a similar issue. In addition, sometimes it would go very dark, but with some difficulty be almost readable. The backlight was definitely still on. I also noticed the back of the display got almost too hot to touch. I ended up replacing the screen and this fixed the issue.
It may just be a loose video cable. My kid’s Chromebook goes black about twice a year. I remove the two screws holding the bezel around the screen, remove the bezel, and carefully tilt the lcd forward. I then push the cable in and try to tape it in place. Takes about 3 minutes.
It may just be a loose video cable. My kid’s Chromebook goes black twice a year. I remove the two screws holding the bezel around the screen, remove the bezel, and carefully tilt the lcd forward. I then just push the cable in better and try to tape it in place. Takes about two minutes.
its the display plug o the screen has come loose and if you bump it you will see the screen will flash then go black take it to a tech place and the can just plug it back in for you, it happened to me too on a school chromebook.
yes mystery man named ryan r
Ryan R crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 9,273
