Will not drain, spin or operate on any cycle
I already tried power cycling but that was no help. Also tried spin/drain setting but that was no help either.
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Do you get any error codes?
Here's the part: Whirlpool Top Load Washer Lid Switch Assembly - 3949247V
Right below the part is a video on how to install it.
That was the problem on mine +
Yes error code 03
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 1,257
Does it power on? I'm guess there's a blown fuse.
crwdns2934271:0crwdnd2934271:0 rab777hp crwdne2934271:0
It has power and will turn on
crwdns2934271:0crwdnd2934271:0 Rob crwdne2934271:0
Mine too same thing
crwdns2934271:0crwdnd2934271:0 mommabear2015 crwdne2934271:0
