Blu-ray player with built in wifi capabilities allows for media streaming of apps such as Netflix, Youtube, and Pandora.
Why is my display black?
My TV wont display my image from my Sony BDP Bx350. Both devices are powered on, but I cant seem to see anything. What should I do?
IS it plugged in and sent to the correct input? Check both cables and try a different one
the issue stems from a failure between the GPU, and the LCD. The components between these are
GPU
Imaging circuit
Display port on device (Usually HDMI)
Cable
Display port on TV
Signal processing Circuit
1a) It is best to start with the obvious. try a different port on each the TV, and device.
1b) If no success, try a new Cable
2) Figure out if it is the TV or Device
2a) make sure the TV processes another device on that port.
2b) If it does, make sure the device runs on a different TV
depending on which it is, replace the port on the failing device.
if it doesnt run, you are looking at board failures. without previous SMT experience, i would suggest taking it to a proffesional to repair it.
Cameron Peterson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 226
