Guides on how to fix and or repair common issues on the 1995-2002 3rd generation Toyota 4Runner. The 3rd generation 4Runner is a body-on-frame truck-based SUV with Independent Front Suspension (IFS) and solid rear axle with coil springs in the front and rear.
My h/lamps won,t comeon
the headlamps on my 2000 4-runner, due not come on.
high beams an p/lamps all work
fuses are good
rdmattia , check/test both bulbs(totally possible for them both to be blown out), check wires/sockets/plugs for corrosion/damage/loose,dimmer relay, faulty switch(test), More info. at the link below. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.toyota-4runner.org/3rd-gen-t4...
rdmattia crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 129
