The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
fuel gauge erratic behavior
Occasionally my fuel gauge jumps left to right and right to left, then resets to correct position.
@lollygirl, David , Check the wiring/plug by the tank to see if loose/dirty/corroded and if able to check ground wire and loosen and retighten to make good connection, if all looks good the in tank fuel sending unit may be faulty or a bad actuator at the fuel gauge on your dash. . See links below for more info and trouble shooting ideas. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://mercedessource.com/problems/elec...
http://www.benzworld.org/forums/w126-s-s...
Mercedes W123 Fuel Sending Unit Replacement
How would I know if my fuel gauge actuator is bad? I noticed that the needle was moving as I moved my sending unit float back and forth.
crwdns2947821:0crwdne2947821:0
David crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,775
