Will not turn on after attempting to change backlight fuse
Hello,
First, my screen was black with a flashlight showing the computer was on. I determined the back light fuse was blown. When I tried to desolder it, I shorted to nearby component. The motherboard was not unplugged from battery.
Now, absolutely nothing happens when I press the power button. Can anyone you please point me to where the problem is likely to be now?
Thanks
Uh, Charles...there's usually a _reason_ fuses blow. Their purpose is to save power supplies and upstream components. Therefore, there was probably a short circuit downstream from the fuse to begin with. Failing to remove power from the unit before applying a soldering tool was a _major_ malfunction! At this point, the problem could be a blown component / circuit trace anywhere in the system! Good luck...
Charles Kensington crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 111
