The third generation of the Samsung Galaxy tablet with a 7-in. screen announced on June 24, 2013. Repair of this device requires screwdrivers and prying tools. The device is available in white or gold brown with 8, 16, or 32 GB of storage, and includes a microSD slot that can hold up to an additional 64 GB of memory.
Samsung galaxy tab 3. Not charging
Tab 3 not overcharged. I have followed videos and advise and have disconnected and reconnected the battery from the board and tried to hold the sequence of different button to get it charging etc.. nothing is happening .... charger clicks in and not loose. Tried many different chargers and sockets and even tried the trickle charge from a pc ... help please
I was planning on buying a new battery, however, following you advice, pling, it's charging again!!! Well done and thank you!!
i just put in a new battery
@lozc ,Laurac , have you replaced the battery, as it could be faulty. A lot of forums feel a factory reset can fix this type of issue, read and follow the steps in the first link below if you would like to try, all data not backed up will be lost.
Reset did not work, The battery, cable/charger, charge port or charging IC may be faulty damaged. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connections and reconnect/install battery, still not charging battery probably faulty or the charging IC may be bad. If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board (2nd link)and the heat generated could cause further damage if not very careful. Good luck.
https://www.androidpit.com/forum/602119/...
https://www.youtube.com/watch?v=0fcqUXtF...
My Samsung Galaxy Tab 3 Lite 7.0 has a broken charger port, could I take the charger port out of a Galaxy S3 that I have and put it in my Samsung Galaxy Tab 3 Lite 7.0?
read this on this site and it worked for my tab 3
Disconnect charger
Hold power button and volume up button for 30 seconds
Keep holding buttons while plugging in charger
Hold buttons for another 30 secs
Release power button keeping volume button pressed
Tab starts to charge
crwdns2889612:0crwdne2889612:0 10
crwdns2944067:010crwdne2944067:0:
Thank you so, so much, honestly!
I was about to give up and send it to a repairing center when I found your solution, and it worked!
GOSH , this happen before and I had to pay for repairs ... happened again , this trick resolved it. thank you kind sir/madam... any idea as to why this does happen to these tabs ?
I've tried this, but it shows like it's about to charge then goes blank. Not charging.
@gabsizaguirre yay glad it helped!
@adhir i really don't know, only found out that this is a common problem with this model
Thankyou - just followed the suggestion of Power/Volume buttons and it sorted my wife’s Tablet out .. cheers.
crwdns2934275:05crwdne2934275:0
Didnt work. Still says 100% charged tho …and works great while connected to power
Laurac crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 41,237
