The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
Shows Error code: 0x9A
When i tried to turn on my printer, it shows error code 0x9A. Please help.
crwdns2889612:0crwdne2889612:0 20
crwdns2944067:06crwdne2944067:0
The printer didn't recognize the black ink cartridge so i removed that and reset. Still didn't recognize so i took out again and reset all cartridges. then 9A error came up so i reset cartridges again now none of the 4 cartridges are recognized. Ready to "office space this piece o'junk" PS worked great for 2-3 years.
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Never ever put remanufactured ink in this model. If you do you have a very expensive office decoration and need a new printer. Never ever will I buy Epson again.
i agree epson is a great door stop i have ad 2 xp 860 one was a warrantee replacement and both ended up with the 0x9a error code and locked the machine all up so now i have a door stop, i went out and bought a canon mega tank........ so far so good
I’ve only used Epson ink in mine and have this code. But I’ve also used this printer for almost 10 years so I’m not really that upset.
I had an ink jam, bought new ink- didn't work, cleaned head-didn't work, bought new head, - didn't work, new ink for new head - didn't work, error keeps me from access driver download to try load updates?. Looks like I buy a new printer and NEVER EVER BUY EPSON AGAIN!!!!
crwdns2933315:09crwdne2933315:0
Sanskar Patel on the Epson WF series that error code indicates a carriage fault. That can be caused by debris/obstruction (paper jam, bent/damaged rails, out of place purge assembly/wiper, or dirty/dislocated encoder strip) to a bad sensor or control board, faulty carriage drive motor/gear/belt, bad printhead/carriage pcb. also check the ink cartridge holder and make sure it is properly seated. As you can see it is a broad non-specific error code that will require you to check the aforementioned things first.
crwdns2944067:09crwdne2944067:0:
Call the Epson 800# for support for this code and was prompted to pay $199 for them to fix it remotely and the tech wanted access to my computer .....never buy an Epson again !!!
I will never buy an Epson printer again!!! Nothing but clogged print heads and error codes!
Were the tech support sites Epson or third party? If it was Epson and
they are charging for a remote fix, that tells me two things;
1. If it was a third-party support site that wanted access to your system,
that should send off signal flares that you are being scammed.
2. If it was Epson Tech support, I would still be concerned. The last
few firmware updates nagged me over using third-party ink cartridges.
It might be that Epson is shutting down printers unless the owner
uses their overpriced ink.
Finally, I live in the High Desert of Southern California. Sand, dust and
my case cat hair (my pet sleeps on the printer,) are everywhere!
Once it cools off, I am going to lug it out to my back porch and fire up my compressor and blow the snot out of it and give it a good inspection once
it cools off this evening. I will post the results.
After a thorough cleaning, my printer is still a brick!
I am having this problem but the carriage will not move from the far right position. I can see a small white plastic part sticking up and blocking it, but I have no idea what it is or does. Clear it is not supposed to be in the position it's in as it completely blocks the carriage from moving. Any idea how to correct?
crwdns2934275:04crwdne2934275:0
Sanskar Patel, Try to clean and reset your printer to get rid of the Error code: 0x9A/carriage fault.
Open up the printer check for scraps of paper, lint or foreign objects,staple, etc. Make sure carriage moves manually, or moves on its own when raising lid. If moving freely, continue cleaning with compressed air blowing out inside printer compartment while checking both sides are clear, wipe down the encoder strip with a soft cloth and a few drops of alcohol, it is a clear plastic strip running the width of the printer, that sits just slightly above and behind the carriage. Now reset the machine, detach printer from outlet, wait 5 minutes then press and hold power button a minute or two, while still holding power on button plug printer in and continue holding button for another minute after plugged in, release button.
Find below a link trying to solve problem of similar issue. Good luck.
http://www.justanswer.com/printers/8l19o...
There are many causes of this error if we are taking care of this causes then we get rid of Epson Error code 0X9a easily. Like
• Configuration error of framework records in Windows.
• Corrupted files in the framework records.
• The framework records in Windows OS are spoiled due to inappropriate removal of apps and hardware.
@elizaswift careful when you link to one site consistently. It comes across as Spam to some and that is not tolerated on here.
this is a printer error not a pc error, your answer totally misses the point
I am thinking it is the encoder belt - long clear plastic belt about 1/4 inch wide. It sits behind the print head and runs left to right.
If this has jumped out of the guide rail of the print head it will cause head to malfunction with various error messages including that one.
Generally, this error code 0x9a comes in Epson Printer and other models can be seen as a notification that tells that there is some problem with the device. It usually occurs in the printing process. When this error occurs, your device may be unable to print.
Apply the troubleshooting steps given below in resolving the Epson Printer Error Code 0X9A.
:- First of all, apply the manual process.
  • Steps to Resolve Epson Printer Error Code 0X9A Manually
  • First of all, shut down your computer.
  • Wait for few minutes and switch ON your PC and sign in as the administrator.
  • Tap on the Start option and then go to the Control Panel.
  • Navigate to the Backup and Restore option and then select the System Restore option.
  • Now, select the Restore My Computer to an earlier time option.
  • Then, tap on the Next button for initiating the restoration process.
  • After the restoration process, restart your PC.
Check if the Epson Printer Error Code 0X9A is fixed or not by printing a sample document from your Epson Printer.
IF not You can also try this for ***Fix Epson error code 0x9a***
Cleaning the Printer
  • First of all, you need to cancel all the print jobs from the queue on your PC.
  • After canceling the printing jobs, open the top cover of your Epson printer machine.
  • Have a proper look inside your printer and clear any dirt, debris, pieces of paper, paper pins, staple pins, or anything else.
  • Once you are done cleaning the dirt, press the Start button on your Printer and try printing something.
If your printer continues to show error code 0x9A, then move forward with the next steps and follow them until your issue is fixed.
  • Search for the Epson Printer Error 0X9A repair utility software on your web browser.
  • Now, download the Epson Error 0X9A utility tool from a trusted web link.
For quick access, save the setup file on your desktop or laptop
  • Now, go to the setup file and install the software by following the instructions.
  • After successful installation, open the Epson Printer Error 0X9A repair utility application and click on the Scan option to initiate the scanning process, and then click on the Fix Error option.
  • Restart your PC once the fixing process is completed.
Now do a print a job to check the Epson Printer Error Code 0X9A is resolved or not.
I hope you will be helped!
  1. I don't have any idea of what to do about a lot of issues.. I try to understand why a very successful company would find the headaches and bad talk were worth selling some ink cartridges and that the aftermath wouldn't scar the company for life. There are hundreds of thousands of people with like problems. This huge company did not make this happen on purpose. Today its too easy to just go somewhere else. My in site Alan
I too have this issue.
I followed some instructions online by cleaning this, cleaning that, press and hold the power button, unplug it etc etc etc.
I then has an online chat with Epson, they told me to do one thing…it didn’t work and suggested to book an engineer of around £130!!!
Epson has to take some responsibility for this error message as it’s happening to too many users - so there must be a problem! Just like the cars that are malfunctioning!!!!
I need a printer for my business so need to either fix this one or buy another asap and I need one that includes A3 paper and there isn’t many of them that have good reviews….
Epson Printer, without any doubt, the most reliable printer brands serving all over the globe. Then Epson is the printer brand that can offer you the best if you want to buy a printer but have a tight budget. However, there are times when you can face some errors along with your Epson printers which can be not an pressings issue if you can fix them. You may want to reach Epson Support for immediate assistance and allow them to fix your printer.
The causes of Epson Printer Error Code 0x9A?
Once we said above, all the time Epson Error Code 0x9A occurs as a result of a fault when you look at the printer cartridge. However, that’s not the only reason that may cause this error. There are numerous other notable causes of Epson error code 0x9A for example once the paper tray is blocked as a result of debris or bits of paper or even the encoder strip is dislocated or even the rails are damaged. In some rare circumstances, the error can also occur because of hardware defects like defective printer belt or gear, print head, or carriage driver motor. In such instances, you got no other option except using the help of Epson Support professionals. However, we suggest you try the below methods to troubleshoot Epson Error code 0x9A in your own first.
Solutions to Troubleshoot Epson Error Code 0x9A
Now it exactly, you can work on its fix that you know what are the possible causes of Epson Error Code 0x9A and what is. For you instead if you are in a hurry and want to get your printer fixed immediately, you can also take the of our printer experts and let them do it. Otherwise, the steps can be followed by you listed below to repair Epson Error Code 0x9A on your own.
  • Let’s Focus On Cleaning the Printer
  • First of all, you ought to cancel all of the print jobs from the queue on your PC.
  • Have a look that is proper your printer and clear any dirt, debris, pieces of paper, paper pin, staple pins, or whatever else.
  • Once you are done washing the dirt, press the beginning button on your Printer and attempt printing something.
Then move forward with the next steps and follow them until your issue is fixed if your printer continues to show Epson error code 0x9A.
  • Press the Power button to modify it off and then open the scanner unit.
  • Remove any jammed paper or torn bits of paper if stuck.
  • Now close the scanner unit and turn on the printer from the charged power button.
  • Load papers that are new the Printer. In the event that you don’t know the procedure, proceed with the paper loading instructions on your screen.
To check if the issue is fixed or otherwise not, print a test page. If the printer still displays Epson Error Code 0x9A, then continue with all the next method.
Here is a guide that will help you eliminate Epson Error Code 0x9A so that your Printer can work as it did before.
What is Epson Printer ErrorCode 0x9a?
No doubt, Epson Printers are among the best printer brands in the world today. Occasionally, Epson printers can have errors that can be fixed as long as you know how. Throughout this blog, we will discuss one such Error Code 0x9A in Epson WF-2540. A faulty printer cartridge is usually the cause of the error
How does Epson Printer Error Code 0x9A occur?
Apart from faulty printer cartridges, there are several other reasons for Epson error code 0x9A. The paper tray may be blocked by debris or paper pieces. Or the encoder strip can be dislocated. Sometimes the error occurs due to hardware defects, such as a defective printhead, belt, or gear. If Epson Error code 0x9A persists, try the following methods on your own.
Solutions for Epson Error Code 0x9A:
Following the steps below will assist you in fixing Epson Error Code 0x9A on your own.
We'll start with cleaning the printer:
  1. On your PC, cancel all the print jobs in the queue.
  2. When you've canceled the printing jobs, open the top cover.
  3. Remove any dirt, debris, paper pieces, paper pins, staple pins, and other items inside your printer.
  4. Next, try to print something once you have cleaned the dirt off your printer. The next steps will help you resolve Epson error code 0x9A if your printer still displays this error.
  5. Initially, press the Power button to turn it off, then open the scanner.
  6. Then, identify any jammed or torn pieces of paper and remove them.
  7. Afterward, put the scanner unit back in place. Now turn on the printer by hitting the power button.
  8. Next, put new papers in the printer. To load paper, follow the on-screen instructions if you do not know how to do it.
  9. Print a test page to see if your problem has been resolved. Continue with the next method if Epson Error Code 0x9A remains.
Monitor the Movement of the Carriage
Open the top cover of your Epson Printer and look at the carriage. Alternatively, you can just close the lid and proceed with the next step if the lid is moving automatically. Nevertheless, you need to move it manually first if it is not moving. If that doesn't work, blow compressed air inside the printer compartment to remove the dirt.
Then, close the lid of the printer after cleaning the carriage of dirt. Attempt to print a test page and see if Epson Error Code 0x9A persists.
Check and Clean the Encoder Strip
A dirty encoder strip can cause Epson Error Code 0x9A. Located at the top of the printer carriage, it is a plastic strip that reads its speed and position. Occasionally, cleaning the encoder strip can solve problems with your Epson printer when it is dirty.
Furthermore, avoid pulling or rubbing your printer's encoder strip harshly, as this can damage it permanently.
Epson Printer Machine Reset
Try this if all the above solutions fail to fix Epson Printer Error Code 0x9A. A reset of the printer resolved many complicated printer issues. However, if you still have problems, you need to contact Epson Support.
  1. You must turn off and unplug your printer first.
  2. During the next five minutes, keep the printer turned off.
  3. Press and hold the power button for one minute to drain the printer's residual power.
  4. Release the button only after your printer has been completely shut off.
  5. Afterward, reconnect your printer to the power source and press the power button to start it again.
  6. A message "FW Update Mode" will appear on your screen when your printer turns on.
  7. After that, choose Firmware from the Update Devices menu.
  8. You can now start the update by clicking on the Update button.
  9. Upon completion of the update, click “Finished”.
  10.  To turn off the printer, click on OK.
Try printing a test page from the main menu to see if Epson Error code 0x9A persists.
The Last Words:
Nevertheless, if this error continues to appear on your printer, you should call the professionals for assistance, as this might be a serious issue.
Sanskar Patel crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 196
crwdns2959996:0crwdne2959996:0 92,889
